here is the work that has been done to the car, as desribed for the seller
''Ok Now the car has some engine, computer, turbo mods done, This stuff was all done in 2004 by Hitech motorsports in Elk River Minnesota. The car dyno'd 428ftlbs and 411 hp on the 248 dynojet in April of 2008. Have Dyno sheet also.
Accel Gen 7 Stand alone computer, with knock control, torque conversion kit, and ac control,JE Pistons, reconditions factory rods with Arp Rod Bolts, Main Studs, Head bolts. Custom Hyd. Roller cam conversion, with iron gear, roller lifters. Stainless valves, 1.77/1.50, bronze guides, valve job. Gm performance rocker arms. Block was lined honed, decked, balenced rotating assm, dowel tru blelhousing dowel locations. Has a TE61 turbo charger with 3'' down pipe. 72lb injectors. 255 intank pump. Transmission has stock converter as far as i know but has a shift kit in it. Has 3'' exhaust into a flowmaster muffler and doesn't sound that bad. Has aftermarket front mount intercooler in stock location. Also comes with Factory Innercooler. The bill was 13800 for all the work done @ hitech minus the innercooler inwhich was done down south somewhere. Car has adjustable boost controller also, along with a High flow cat. I have a Detailed bill on the work done at hiteh motorsports''
the car has 26k on it and has been sitting since 4/08, i am having it shipped to me
