TTA RPM thru the traps in 3rd gear
Dominic
What are you guys with low to mid 120 mph TTA's going thru the traps at in 3rd gear? Without converter locked, stock rear gear ratio, and a 26" tire. I suspect my converter is too loose, but want to compare with others mph/rpm
3rd gear i'm going thru traps without converter locked at 6025 rpm and just a tick under 124 mph
3rd gear, 28 inch hoosiers, 3.50 gears, vigilante 5 disc locked 4400 rpm's through the traps 135 mph.
Michael
