OK TunerPro RT experts, what am I doing wrong??
I have been successful in getting the Scanmaster G to talk to TunerPro RT via Bluetooth. All seems well except for one particular data point.
My issue is, the Boost isn't reading correctly, while everything else on the TPRT dash is reading perfectly.
At key on engine off, you can see in the picture that all but boost are reading correctly and they agree perfectly with what the SCMG is showing.
Boost on the SCMG reads 0.0, while the tunerpro is showing -10.5 I must have something set wrong, any ideas?????
I just can't figure out why the data going into TPRT is good except for the boost. I must have something set wrong.
I should also add that the adx file I created started out as SCMG_BT_001
It's the only adx file for the SCMG that I could find that had turbo boost as an available value.
