trying to tune the buick! its been parked for about 3 months it was at the bodyshop where the battery was taken out so all my tuning defaulted..so i just finished spring cleaning new fuel filter new plugs r42ts gapped @ .32 new air filter new pcv valve..also just made my own boost controller from an air compressor psi adjuster....so my TT chip is for 30# injectors 22/20 deg timing @ 21-22psi on alky...running an SMC alky single nozzle with denatured alcohol.. i cant pass 15lbs of boost without having some knock..the o2 rdgs look good in the 800's but im getting some knock...i went into the fuel adjustment and added 18% gain at WOT on all gears.. and raised up my FPR to about 40# with vacuum on still got knock??? went in on 3rd-4th WOT timing spark curve and took away about 4degrees of timing..still getting some knock?? WTF???please help any suggestions?? can my injectors be clogged im getting good o2's but having some knock?? what do i try next?? have been testing since 7pm its about to be 3 am...FML also the knock wont come in till higher in the rpm range once in third i'll WOT and 3/4 seconds into it my knock gauge will shoot me 2 green dots and i let off what givess?? take out more timing? it ran fine before i even put fresh 93 octane today
