54Rich
- Apr 10, 2007
I recently went through the motor and trans, just a bit of freshening. Here is what I have:
Stock block, Comp 980 Springs, DBl roller timing chain, new valve guides. Matched the heads to the gaskets (Very mild porting). Motor runs really well, thought vacuum was low, but my gauge is off. Idles at 15 mmHg. 170 degrees, 16 PSI oil pressure (Idle) when warmed up.
Stock Turbo, RJC Power Plate, Adjustable FP Regulator (Set to 42 PSI, vacuum off), 42 Lb injectors. RJC Boost controller, adjustable WG. SMC Progressive kit with 50/50 Alcohol/water mix. TT chip. 4” big mouth air intake, LS1 with a translator, ditched the EGR and the stock WG controller. New wires, gas filter, O2 sensor, plugs, etc. All the gaskets I put in the motor were GM gaskets. TPS and IAC set, BML’s 123, all looks very good, motor sounds great! No Leaks!
BFR Trans with a 2800 stall convertor and CK shift kit.
I’m having a few issues and don’t want to blow the thing up. Here’s the list:
Trans is not shifting correctly, seems to stick in first only when going really slow and then slams into 2nd. This only happens when slow speed. Get on it a little bit and it’s better, 1st to 2nd is a bit harsh. I’ve adjusted the TV cable and does not seem to help.
Also, the convertor will not lock up and I’ve confirmed that it is a lock up (Used convertor)? I have to say that both chips that I have (ALKY and 93 street chip) are burnt for a standard D5 lockup convertor (Does this matter?) Anyhow, I’ll be talking to Chris (CK) in the AM about the trans issues.
Getting back to the car. I put the Alky chip in first and notice that the boost comes on very fast, so fast that I can’t really get into the record mode of the Scan Master. I get knock with anything over 15 lbs, so I have been quick to get out of it. Don’t know what’s with waste gate, but can’t get it adjusted to under 15 lbs of boost? I’ll be pulling it and testing it with a compressor to make sure it works. (I bought it used, so who knows)
Not being able to control the knock, I put the 93 street chip in, thinking that it should be easy to get the car back to where it was last fall which was 16 lbs boost on 93 with Zero knock. Now with the Alky, I can’t stop the knock? I’ve verified that the SMC pump works. I did have one recorded knock and that was 1.2, my 02’s were 814? Could I be drowning this with the alky? This is one variable that I don’t fully understand.
So that’s where it sits, any help would be appreciated.
As always Thanks!
As always Thanks!
