TurboTdr3.8
- Jan 15, 2013
Is it best to tune through the TT chip or through the translator or both . what seem to work for you , I have the SM and PL .
SignUp Now!The translator only works as a tuner with the Bailey chip. The wot setting will make a TT chip get rich quicker which may be needed but wot fuel is only changed through the chip itself, in your case with TT chip. The base setting in the translator is set based upon what type of MAF you are using: LT1, LS1, Zo6, etc. Set that and leave it unless you need to tune your idle BL's. I think you need to read up on the translator operation before you start changing the knobs. The TT forum has much info on the use of them.
hello; So the translater is just to adapt a newer MAF sensor thats it? And if you tried to tune thru it what would happen? Would the chip just over ride any ajustment that was made?
IBBY
When you visit a forum to gather information on something you know nothing about,how do you know if the information you're getting is complete. There are a hand full of opinions that are propagated by a few in this community that get repeated/parroted by many. We have so many people using the TT chip and translator. If we were all equally informed we would come to understand what an awesome combo the Translator Gen 2 and the Extender or Extender extreme is. These two items are made to work together to offer a very wide range of tuning ability. The application that the Extender and Translator shines the most in is when using E85. It allows an easy transition from E85 to gasoline and vice versa.This board rocks !!!!!!!
A very fine product indeed.the TT chips are fine in their own right
What was the settings he suggested ? He just said to do only my tuning in the chip not in the translator .....I set the translator as Eric suggests
If your car is running good,that's all you need to do. If you put some xylene or E85 in with gasoline,to increase octane, you could run more boost. If you do this you could then look at changing fuel and timing,otherwise set it and forget it. Even if you left all the settings the same while increasing boost,it would still run great as long as your fuel system was able to add the extra fuel that the extra boost would need. Of course,feedback from an oxygen sensor,knock sensor,and fuel pressure gauge would need to be monitored for best results.I just set it and forgot it.
hey Amelio; How do you tune if the chip over rides it? I guess you can change fuel pressure but that's about it. Is that true.
IBBY
