- May 28, 2001
So I am trying to tune the alky in correctly using a FAST and WB.
Cal was nice enough to talk to me about this while being on hurricane watch at the same time.
Here is the combo.
Stock block, stroker crank, forged everything. Iron heads, ported and polished with LS1 valve springs. 212 cam. Liquid intercooler.
66 triple ball bearing turbo, 72 pph injectors, dual fuel pumps with a Hobbs switch and Razors alky.
So far I have been trying to get the car to run on pup gas only. I have played it safe with timing and AF ratios so far.
Here is the gct files and a data log run with pump gas only.
Here is the data log of a run. This is on a deserted stretch of road but you will get the idea.
At this point I was worried about hitting detonation so I turned on the alky at 4. Set points are from the factory.
Here is the combo.
