Is it true that as long as there is no knock, I'm safe pulling fuel out via turbotweak chip? I was told it will show knock if it gets too lean. The wideband readings are 785 wot. It is a little slow to accelerate which leads me to believe it is rich. I need to relocate the egt sensor to pre-turbo & use that to estimate afr. Right now post turbo, it' not getting past 1000 degree F.
