Turbo 400 reverse pattern shifter?
Do a search I posted about this and got a few responses a while back...Scott
yes you can but if the stock shifter is tired you can over a gear because of slack ,misadjusted cable,worn cable etc.the detent spacing is correct so if you spend a little time adjusting it it will work fine.
