A quote for those that believe intercooling is absolutely unnecessary on a turbocharged engine running pure methanol.
"TOO COOL IS GOOD"
"A charge-air cooler is not required for detonation control in methanol where vaporization cooling with mixture enrichment can be done. However mixture enrichment can be used with charge-air cooling as well. Tolerance to pre-ignition or knock becomes great. Increases in engine compression and / or boost can be done for even more power"
This is from a methanol tuner's book that concentrates mainly on old school, mechanical injected, supercharged alcohol, V8 engines.
"TOO COOL IS GOOD"
