Blue like from oil, but I was just hoping that its not bad valve seals or rings. It smokes a little at start up then will somtimes smoke sitting at a light.
It very well could be valve seals. My fresh engine will do this also because when the heads where ported the valve guides where cut down to impove flow and those after market seals don't like sitting on the head like they are suppose too. I'ts price I live with. But going quick makes it worth while.
What did you do to solve that problem you had with the harmonic damper? I'm having the same problem. I am buying an impact wrench so I can torque it down to 250 LBS. Thats what the specs on the OE manual says one should torque that crank bolt. A hand held torque just won't do the trick since max is 100 LBS. I've already worn down two dampers. I hate that noise! Once one floors it it sounds like a rod is going to shoot out!
