Turbo Bolt torque
TTA81
I plan on removing the turbine housing on my GT6776 to port the wg hole. Upon install, what should the torque value be for the turbine housing, 3 bolt flange and oil drain bolts? Is this necessary or should I just snug 'em down?
Shop vac and a dremel tool?
Maybe instead of removing the turbo just use a shop vac and a good carbide bit?
When i did it on my TE45a, there was no need to remove the housing to port it out.
Are you worried about the excess metal hitting the wheel?
BW
