Before you buy another MAP sensor..
Get a digital voltmeter and probe the center wire on the 3 pin plug.. that will be the signal wire coming from the sensor. The stock sensor is a 2 bar MAP sensor. Ignition "ON" and engine not running the voltage on the green wire =2.3 volts dc.
If the green wire reads 2.3 volts.. then the sensor is not the problem but the boost gauge on the dash.
If it reads way higher like 2.5..2.7...2.9.. etc.. then confirm 5 volts DC on the gray wire of the plug.. and confirm ground on the black wire of the plug. If you have 5 volts on gray.. ground on black.. still reads higher.. then you have a bad MAP sensor.
Hope this helps.
