A
anti-chevy
Guest
I just picked up a stock '79 turbo regal, Im about to start working on getting the turbo working again, and I also want to give the car some balls. Im trying to do this cheap so a rebuild and ported heads are out of the question. There dosn't seem to be much I can do Headers wouldn't be a bolt in, and none of the aftermarket intakes out there would work with the stock turbo set-up.
I'm thinking about a cam, carb, down pipe, exhaust, no cat, no smog, no AC, and makeing an adjustable waste gate (some how).
The cam I'm lookind at is CRANE PowerMax #813901 (PAW #) with .416" in., .432" ex. lift / 264*in., 272*ex. adv. duration / 112* seperation angle. Is this cam to big?To small?Or just right?Any other cam suggestions?
Im sure this is a stupid question but what is alcohol(alky)/water injection?How dose it work? How much dose it cost?
Whats this little black box thats wired to my distributor and bolted on to my fan shroud for?
How much boost can I run without an intercooler, but with good gas (94 octain).
Thanks for any info!
