Turbo Drain Tube
MikeStarner
Broke Guy
Looking for a flexible preferably braided oil return tube for my hot air. Anyone know where to get one?
You can order everything to make your own off the net. I am not sure about the hot air cars but just use -10 an hose.
You can get a turbo fitting here Turbo Flanges & Gaskets, Billet T25/T28 GT25 & T3/T4 Oil Drain Flange, RPS-OilDrainFlange | RacePartSolutions.com
I used these fittings Fragola Performance Systems 194510 - Fragola Performance Systems Series 3000 Direct Fit Hose Ends - Overview - SummitRacing.com
Just get the length of hose you need. I used the nylon braided hose instead of steel braided. It was a pain in the @$$. I would use steel braided if I had to do it again.
The oil drain flange is thick so you will have to get some longer studs. Hope this helps. Jeremy:smile:
