I have a TA-49 from PTE and a 3"THDP with a RJC Boost Controller on a internal wastegate. Everything works great under power, what I notice is under light throttle and then letting off a little, I can hear and feel a flutter.
Do you think I need to tighten up the wastegate rod and little(I have it set where it will just slip on the wastegate) It seems like the wastegate puck is bouncing open and close just for a few seconds and only after letting off the throttle. Or, could it be the size of the THDP puck compared to the PTE housing?
