Right now at this moment unfortunently I own a 81 turbo Reagal. (I'M ON A "GENERIC" BEER BUDGET)How do u tell if your TURBO'S bad.No smoke,no vacume leaks,boost gauge is hooked up right.But under full throttle, no boost shows on gauge,just vacume up to 0hg's then just stays there at 0hg's until I get off the throttle.So I took off the Exhaust Elbow(what a bitch on the car!) to check the Exh Bypass and it's working fine.I then checked the turbine shaft end play and I can move it a little but how much is bad?I turned the car on while the elbow's off and the turbine spins quick.So what gives?How do I then tell while driving full throttle if my car's even Boosting when It doesn't show it on the gauge??HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
P.S. Secondaries are working.Just had carb rebuilt.
