Turbo Heat Shield /Cover
MRNYG
I just removed my stock turbo and replaced it with a TE44 turbo. I need to know if the stock turbo heat shield/cover will fit over the te44 turbo because it seems like it doesn't lineup as it should. Thanks.
It's the stock downpipe but the two mounting bolts on the front side of the shield or the mounting bolts on the bracket side that mounts to the engine block are not lining up. Thanks for the reply.
Even with a three inch downpipe a little grinding and it also fits well with the TE44
