TurboV6Olds
- Jan 24, 2010
I'm another newbie. I have a Cutlass with a newly implanted 87 GN drivetrain. I am trying to tune the car and having trouble with the boost pressure. I have a Auto Meter Cobalt 45 psi boost gauge with 30 psi vacum, manual boost controller mounted within 18" of turbo and wastegate. I can turn the boost controller all the way down and still get around 21 psi boost. Does the flow of air thru the controller make a difference? I have turned both directions and it does not seem to make a difference. Could the wastegate be an issue? I am trying to tune the car on low boost but cannot get it. Also having issues with o2 readings (too lean) Have LS1 maf and translator, scanmaster, razor alky, TT chip. I have added 17% fuel thru TT chip and still running 730 o2. Any help would be GREATLY appreciated.
Thanks, Rick
Thanks, Rick
