turbo install ?'s
streetknight
DCVING
When I change the turbo on the car, should I just use the copper gasket that comes with it and that's it, or should I put some high temp sealant, or what?
When I went from the stock turbo to a TE-44, I just bolted the turbo to the header - no gasket or RTV/sealant.
Its made to not use a gasket, but from what I've heard, if you ever do use a gasket, then you'll always have to use a gasket cause it will cuase it not to seal correctly once a gasket is used, I guess the gasket causes the surfaces to not be perfectly flat anymore.
