Turbo OIL DRAIN flange bolt size?
TR Custom Parts
Mark Hueffman - Owner
Just wondering if the bolts used for the turbo OIL DRAIN flange on a stock turbo is the same as aftermarket units???? Been a while since I have seen a stock turbo.:) What size are they IF different??
my CPT-61bb was M8x1.25 which I believe is the stock size. Some of the bigger PTE turbos use I believe a 3/8x?
My lil ol TA49 has 3/8 16 bolts, just wanted to make sure I supply the correct bolts with my turbo drain kit.
Yup when I upgraded my turbo I was a little ticked off to find out the drain bolts are not the same as stock. Ended up being the 3/8x16 like yours. Probably won't be easy to make sure you send everyone the correct bolts.
To elaborate on my install a little bit...
I ended up using a spare pair of studs that hold the throttlebody to the plenum for the turbo oil drain line. That was by far, the easiest install I've ever done. :D
