Jan 9, 2011 #1 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 whats the correct thread size for the turbo oil feed line fitting on the top of the turbo and if i change lines to AN fittings what size would i need?
Jan 9, 2011 #3 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 Is the fitting a female double inverted?
Jan 9, 2011 #4 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 49-blues said: Is the fitting a female double inverted? Click to expand... on the end that the line threads into stock it is. Most just use an AN fitting and their own supply line
Jan 10, 2011 #5 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 What size AN fitting is best to use 3?,4?,or 6?
Jan 10, 2011 #6 GNVYUS 1 Well-Known Member TurboBuick.Com Supporter! Joined Dec 15, 2002 Messages 4,516 I stopped an oil smoking issue by going to an 18", 3an braided Brake Line from my Buick GN oil filter.
Jan 10, 2011 #7 B bison Moderator Staff member TurboBuick.Com Supporter! Joined Dec 19, 2005 Messages 18,053 -4 is common
