I'm at wits end with this.  My Stage motor has a high vloume front cover, 70HPQBB Precision Turbo, a turb saver kit with -4 lines.  I dont think Precision quite has there restrictor fittings figured out for those of us who run good oil pressure.  I'm getting oil into my IC pipes.  The car hasnt seen more than 8psi of boost, which really doesnt matter anyways.  It also has basically no miles on it.  I drain back to the pan and have checked for flow capabilities, checked to see if I have too much oil in the pan that may block the oils ability to return.  Everything is good.  When I bought this turbo and saver kit, Presicion didnt supply a restrictor fitting with either, I talked with Pete and ended up having to buy one.  So it's been on the turbo.  I dont know what else to do aside from puting a regulator inline from the saver kit to the oil feed.  Anybody else have to do this?  What pressure are you restricting the flow to the turbo?  I'm tired of leaking oil all over my new beautiful Stage motor.  ----Jeremy
BTW...It's not smoking out of the exhuast, just leaking into the compressor side and into the IC.
