Umm Yeah I'd call it a little spirited short lived acceleration. These draw through engines don't launch like the '84-7 cars will off the foot or e brake.
I plan to prove that wrong Adam.:tongue::biggrin:
SignUp Now!Umm Yeah I'd call it a little spirited short lived acceleration. These draw through engines don't launch like the '84-7 cars will off the foot or e brake.
Umm Yeah I'd call it a little spirited short lived acceleration. These drawthru engines don't launch like the '84-7 cars will off the foot or e brake.
With the stock turbo, I was able to pull 1.8 sec 60'. Build about 6-7 psi and they will launch well and pull hard. Enough that I needed to buy some big drag radials to hold traction.
Of course you need to get the engine running right for that.
Yeah, mine spools pretty good too once I got my DP on. Now that I took the car apart I realized somehow the exhaust flapper was installed wrong so I had a pretty major exhaust leak right off the bottom of the drivers side manifold.Should spool up like crazy when I get it put back together with out a 1/8" gap.
Hopefully Ill be in the mid 14's by August. I dont see 13.70's far off with a good tune. Granted Rich has a 14.20 on a stock block and everyone says ported heads make a big difference on GN's.
I see low 13's possible with a holley on E85, stock GN compressor and 86/87 headers. Be easy on with a weiand intake too! Then you can scrap the turbo foot, intake, and then do crazy stuff.
Or convert to SFI!![]()
can I see some pics of your car??? sounds cool.
Most peoples drawthru's are a far cry from the shape and tune yours is in, to be able to repeat that performance :biggrin:
That's my point - there's nothing special about my car. No special tune or magic parts. I just made sure it was running right before I started messing with it. No vacuum leaks, no cracked exhaust, good plugs and wires, no check engine lights, no aftermarket carb, etc.
If it's running right, it will peform - Any carb/turbo.
I think Rich has proved his point very well. If you decide to modify the design you'd better make sure what you're doing and not just throwing parts at it. This is one of the problems people have. Just a cam change can screw everything up if you don't know what you're doing!
Ive got some good ideas to make the stock motor perform a bit better IE a bigger turbo,
There's your first problem. You don't need a bigger turbo. You need to get you car running well in stock form.
Here's your recipe:
- Get it running right
- Check for knocking with a gauge
- Figure out how to get rid of knock
- more boost
- Repeat steps 2-4
How much knock are you seeing now and how much boost do you have? If you can't answer this, then no amount of parts will help you.
