hounddogs!
- May 5, 2006
Under mild boost (generally 10-15 psi, 20 max) I was getting the huge blue cloud from the tailpipe. Assumed a bad turbo seal, and the problem went away with a different turbo in place. The 'new' turbo is only set for about 12-13 psi, so I'm not totally sure that I wasn't blowing oil out of the motor due to the higher pressure.
If the 'leaky' turbo has absolutely no slop axially or radially, do I still assume it's a seal and send the thing off for a rebuild? I'd like to be more than 90% sure it's the turbo before I mail it away.
TIA
TIA
