Turbo Seal
whiner
I am trying to find out if the turbo oil seal for the stock turbo is available seperately from the turbo?
Or do you have to replace the complete turbo? If the seal is available seperate, then who sells it? Mine smokes when cold started and I believe its the turbo seal as I have read on here. Any info would be appreciated.
Yes you can get it by itself but if it's leaking you still need to take it apart so you might as well go through it and replace everything else.
Do you know if someone makes a complete kit or do I have to buy all the parts seperate?
