I was also under the impression that Carrillo, as well as the Olivers were both made in USA. You have to break it down to HP per cylinder to see the stress load on each rod. If " Large Father" is making 1500HP / 8 cylinders you will get 187.5 HP per cylinder. A 6 cylinder at 1500 HP is 250 HP per cylinder. The same rod get more load in a 6 cylinder at the same power output. Extreme RPM will stretch a rod, Extreme cylinder preasure will bend or compress a rod . This is the case in our V-6's, Also the StageII rods are usualy about 6.300 to 6.500 long. The ford set up are much shorter (more strength). The finish machining on the Oliver rods that I have used was nice. I'm not sure but I think Dwayne might be using crower internals now. Hope this clears some things up for you. Dwayne is the Drag Radial King.
