turbo step up?
Cleaner13
The Cleaner
ok these are my following mods thus far
Gauges boost, temp, oil, tach, knock, air fuel, fuel pressure
RJC Powerplate
92Thrasher chip
THDP with cutout and dump
Duttweiler Neck
Engine Tie Down
ash tray Switch Plate torque converter, fan relay, fuel pump
Pinion Snubber
Volt Booster
Big Mouth Intake
B& M Tranny Cooler
160* Thermostat
Racetronix plug and play with fuel pump
Driveshaft Loop
Adjustable Fuel Pressure Regulator
Scan Master
2 pod Console Pillar
Hooker Exhaust or the dual atr exhaust
HRPartsNstuff lower and upper control arms
Upgraded Crossover Pipes
Aluminum Pulley
CAS Radiator
Jay Jackson Throttle body and Plenum port and polish upgrade
Ramchargers Boost Controller
GTA Black Honeycomb wheels
recalidbrated 145MPH Speedo
Eibach lowering spring kit
Shocks what kind should I get?
3 Pod A-Pillar Lotek
Rear Seat Brace Kit
Shift Kit
SMC alky kit
what turbo is a good step up from stock? I want something reliable and not have to worry about rebuilds and such, but I want a moderate to fast spool up with some good potential power, this is about as far as I am gonna go with upgrades, so what would be good for my setup and where could I get this turbo at
thanks alot guys
Carl
i didn't see injectors on that list, something that needs to be done with an upgraded turbo
A few guys i know that upgraded from stock are running TE-44's or TA-49's but it all depends on what you want to run
I'd upgrade the injectors to either Blue Tops or MSD 50's, the stockers won't cut it.
I'm sure other people with more knowledge will chime in, but this is what i've seen people upgrade to :)
thanks alot man
I also failed to mention that I do not want to change the converter if I dont have too
Carl
TE-44 / TA-49 and Blue Tops / MSD 50's. A tried and true combination that has worked for thousands of us and it can be done with the stock converter.
Call Patrick at:
Precision Turbo & Engine
You are going to need a new chip with your injector choice and he can help you with that as well.
Good Luck,
