Hi Tim!
Excactly what mod's do you have? None? Only gas and boost?
Anyway..... the problem getting boost on the line is well knowned by me as well...... first the heat, then to much fuel..... fuel isn't so bad, but the heat kills the IC on our cars.
Try and drive the car hot, let it rest in the sun for 5min. and try to get some boost..... guess no boost now, take the car for a drive at 50mph for 5 min, directly after that..... stop the car and try building the boost..... guess you get some boost now!
There is reason that a few TTA's had the watercooled IC stock mounted. (5 i think)
Anyway.... after learning these cars and the 250hp@340ft lbs is way higher.
We all know that they where dynoed at 301bhp but no numbers on the tourque, looks like stock tourque should be over 450 ft lbs.
