turbo to exhaust bolt size?
sams86gn
I seem to have lost the 3 bolts that hold the turbo to the exhaust...does anyone have some laying around or does anyone know what size bolts they are and where I could order them from? Thanks
M10x1.5, I think... Not sure but it sounds right to me. Been a long while since I had mine apart.
Pretty sure that's right though.
Hope this helps.
They were 10x1.5 studs. Bolts werent used but could be
In a pinch - old stock exhaust header bolts will work - you can leave them in, it will look wonky unless you cut off the other end.
Thanks for all the replys, There is one stud left in the exhaust but I have no idea what happened to the other 2 and I cant remember if they were in there when I took it apart. I guess I will make a run to the hardware store tomorrow and see what I can come up with! Thanks
