Lil Truck
I spend to much time here....
- Sep 26, 2002
I reciently installed a new motor and 200r4 trans combo that is running fine, but my PL logs show 3&4 pressure valves on all the time. They are disconnected in the trans I found out.....
My question is with the valve always showing on how is the timming change occuring from 2-3 gear change?
My PL log shows the timing change occuring around 55 mph at full throttle in 2nd gear manually shifted.
6.1 Alky chip.
I am getting ready to order a new chip and injector combo, Is it possible to have a new chip programmed to work without the 3&4 valves operating?
Eric or Bob please informe me of the options.
Thank you!
6.1 Alky chip.
Thank you!
