May 2, 2006 #1 C carrddine boost junky Joined Sep 11, 2005 Messages 360 I have a turbo tweak chip and it was cut for alcohol and 23 deg of timing and I am curious if I have to adjust the chip to get 23 deg or if it is already set for 23 deg?????thanks in advance....
May 2, 2006 #2 E Eric Stage I TurboTweak Guy Joined May 25, 2001 Messages 2,667 The timing is written on the chip. For alcohol, normally 23/21°. That's the default timing. Regards, Eric
May 4, 2006 #3 E EGOKILR Dont Worry, Be Happy. Joined Dec 22, 2005 Messages 529 Numbers dont lie just get a pen and write 26 on your chip and you should now have 26 degrees of timing :biggrin: Just saw your post thought I would crack myself up.
