Turbo upgrade suggestion
z28up
I just got my car back and I'm going to upgrade the turbo. Wanting one that is a direct bolt up...And looking for suggestions. Also an will I have to change my stock intercooler?
Goal:
- mid 11's
- cold a/c
- extremely dependable/drive anywhere
List of mods below..
On the way
80lb injectors
Alky chip
1972 Chevelle 505
1972 dart swinger 340 4speed
1966 impala
1955 chevy pickup MickeyRat
2002 monte ss DD
1987 Grand National
Stock turbo ,Red 93 street tune chip, 206/206 comp cam, valve spring upgrade, Melling hv oil pump
37lb injectors, Ls1 maf with translator, Oil filter adapter upgrade
K&N filter
Sitting at home not installed yet:
AlkyControl "Razor" injection with 3 bar map, Hot wire kit, walbor pump upgrade, RJC Racing Airflow Distribution Power Plate
15x9 4.25 bs weld prostars 275/60
15x7 weld prostar
1972 Chevelle 505
1966 impala
2002 monte ss DD
1987 Grand National
K&N filter
15x7 weld prostar
I like the 5858 Billet Precision Turbo Unit…
Contact Bison to see what he’s able to supply you with in that range.
I would keep the Garret .63 exhaust housing for mid 11’s.
Thats the only thing I’d change about the 5858
X2 on this
You're on the right track getting bigger injectors and a matched chip for Razor's kit. I know from experience that that kit saved my bottom end at least once when I got impatient while tuning it and accidentally cranked the boost to 30 PSI. You can run 11s on the stock turbo, but it's pretty rough on it. I ran 11.57 at 119 on the stock turbo, but that was with the 30 PSI mistake.
TA-49 and TE-44 are well proven turbo's that work well with the d-5 stock converter. Stick to the Garret .63 exhaust housing. Both are 11 sec capable but remember it takes more than a turbo boss.
If your keeping the D5 and untouched heads, te44, 5857- 5957e covers , te60 the limit.
