Turbo
TKMBUICK
I what to get a new turbo but not sure what to get I use the car for the street and strip.
thanks
Is there a budget with a GN...?
Mine is like a crack addiction..sell the TV and microwave for a new turbo. Sell the sofa for a new intercooler...:D
LOL! :biggrin:
If you have a 3200 stall I would go with a PT-61 that turbo is awesome. It will max out unported heads to the low 11's and with ported heads high 10's. Great street manners also.
Ok here's what I have done.
Houston 3" down pipe with cutout,Houston 2 3/4" cat back with dyno flow ulta flows, Underdrive crank pulley, K&N filter, LT1 value springs, 42.5lb injectors, ATR fuel pressure regulator, Fuel pump hot wire kit, EGR block off plate, Brass PCV, RJC power plate, Cotton's high voltage coil packs, Air volt booster, 160 Thermstat, Duttweiler big neck on stock intercooler.
What converter? How fast do you want to go? How much you looking to spend?
TA49 or TE44 will work.
Stock turbo would probably get you those times.
Yeah, get alky, wideband, and powerlogger. Done.
No turbo needed. If you do get one later, you didnt waste your money!
