Turbonetics 62
dpasadena
DSCN3940.JPGDSCN3941.JPGDSCN3942.JPGDSCN3943.JPG [/ATTACH]
This turbo has less than a 1000 street miles on it and has always been run with a turbo saver. Journal bearing and has a 62mm compressor wheel and a 65mm exhaust wheel. The wastegate hole has been ported to 1 1/16". 4" inlet and 2.5" outlet compressor.
.63 exhaust housing. Took it off because we did not have enough converter to spool to our satisfaction. We replaced it with a smaller unit. Our stall is 2600rpm@0 psi. $550 shipped
View attachment 187395View attachment 187396View attachment 187397View attachment 187398 [/ATTACH] View attachment 187398 This turbo has less than a 1000 street miles on it and has always been run with a turbo saver. Journal bearing and has a 62mm compressor wheel and a 65mm exhaust wheel. The wastegate hole has been ported to 1 1/16". 4" inlet and 2.5" outlet compressor.
.63 exhaust housing. Took it off because we did not have enough converter to spool to our satisfaction. We replaced it with a smaller unit. Our stall is 2600rpm@0 psi. $600 shipped
ttt
ttt
ttt
