Turbosaver Priming the lines
aminga
Chicks Dig the powerbulge
How many of you prime the lines after installing the turbo saver. I filled the filter but there doesn't seem to be a way to fill the lines without all of it running out.
Now I was thinking with a fitting and a pressure gun you might force it in through the turbo feed and fill the lines but I'm not sure if that's really worth it.
Pull the cam sensor and use a priming tool.
