turn signal and brake light grounds
Does anybody have a wire diagram for an 86 t type for the turn signals and brake lights? Or know the location of the body grounds. I bought a car in pieces and not all the lights work correctly. It seems like a ground problem with the turn signals, If you turn on the left turn the rears light up ok but the front is dim then when trying the rights the front is bright and the rears are dim and the reverse lights also come on dim at the same time, Also the brake lights in the rear don't come on but the 3rd brake light does come on when applying the brake.
front end harness grounds to the r+L fender at each side- one by battery- one above horns ,
the tail harness grounds inside the trunk at rear on driverside
ok thanks, I did check them and they are good, I thought maybe there were some more. Starting to think it might be the multifunction switch is messed up.
