A. G. Olphart
- Jan 14, 2004
Do all 2004R TV valves require the same overall travel?
Same as 700?
The reference diagrams I've located on the net are for the 700, and show a center to center distance of 1.094 to 1.125 throttle shaft to TV pull pin. (Pull pin 23 degrees to the rear of throttle shaft with throttle closed).
However, an electronic Quadrajet (#17086003), pulled from a Monte SS for the throttle shaft measures 1.175 (.050 too long). The angle looks about right.
So what is right?
Same as 700?
So what is right?
