1985BuickGN
- Apr 20, 2002
I have a friend that put a non-lock up converter in his trans and used a transgo kit which required him to remove the o-ring and check ball from the turbine shaft and install a new clutch valve train. By mistake he removed the tv boost valve first and apparently he didn't get the snap ring seated correctly when he put it back in.
They took it out for a test drive (2-3 miles with 1 full throttle hit) and it didn't feel right so he parked it back in the garage and called me. I went over and we dropped the pan, fluid smelled burnt and there was black material at the bottom of the pan along with the boost valve and snap ring. I put it back together and cleaned the pan and lines and cooler out, put in new fluid and test drove it. Reverse seemed ok backing out of the drive, but when it went to drive it took a lot of RPM's to get it going and it felt pretty sluggish. We only went to the end of his street and back, don't know if it even shifted out of first. Anyone know if it's toast or if there is a simple fix.
Thanks for any help.
