I have a 87 GN, stock trans that was built, with a shift kit installed by the original onwer. My problem is the trans shifts good and hard, but if adjust the cable to specs, it doesnt shift until about 3500 to 4000 rpms, at normal driving. If you go wot it will not shift until you let off of the gas some. If you give it 3/4 throttle if does great. At wot it over revs before it need to shift. We went out on a backroad and worked with the cable in and out and it to shift a little better. At wot 1-2 gear at 5200 rpm & 2-3 gear at 4800 rpm. I want it to change about 4600-4800 at all gears. Could anyone help me figure out what is going on?
