TV cable proper under car routing
87chrisss
BLUBYU
where is my TV cable supposed to route from under car to TV bracket its loose and cant remember where its supposed to be its causing me to shift 1-2 early on part throttle pic would be helpful cant find it on google
TV cable snaps into the bracket on tbody. It should not matter the route as long as it is not kinked and is attached at both ends. TV cable will affect all shift points not just 1/2. You may have other issues.
yea it was kinked on the front i fixed it already it was simple mistake when i changed the tb gaskets because i thought i had a vacuum leak my bl's were high and i started replacing plenum gaskets and etc... but its fine now thanks,
