Two interior lights won't turn off! Help!
Kelton Roberts
I finished installing the alky kit and a knock gauge and went to test them and both the knock gauge and alky kit seem to working properly but now I have two lights inside the car that won't turn off. Please help!
yoy probably grounded the swith wire messing by the fuse block check dome wires to drivers switch behind e brake
I'm not exactly sure what happened but I plugged the battery back in to see if I could find the wiring issue and the lights went back to normal. Maybe there was an issue when I plugged the battery back in the first time. Not 100% sure but I'm glad everything is working as it should be!
