SEFi8LOxCivic
- May 25, 2001
Does anyone have a two step running on their FAST?
Craig, if you're reading this, I know when we spoke you said to setup the closed loop enable point above the two step activtation RPM to avoid a falsly rich condition detected by the O2 sensor, but I've been talking with a pro class import racer who also runs fast, and I was wondering if I could run his idea by you.
How he does it is he keeps the closed loop rpm where it normally resides, which is 1200 give or take. And instead what they're doing is retarding timing by a lot on the cell where the Two Step activates. This appearently allows him to build boost on the line without the fear of having a lean condition occur due to the falsly rich condition read by the o2.
Any thoughts or comments on this?
Thanks.
Thanks.
