SignUp Now!What are the "typical g-body problems?"
I am trying to learn more about the weaknesses of these cars.
#6 body mounts rotting out. just behind the rear wheel. head gaskets on grand nationals. mine just blew. bushings, bushings, bushings, and more control arm bushings....lol window/ t-top rattles. audio systems suck!
They end up giving you a monopolistic Personality :biggrin:
Body's are never on the frame straight from the factory on a GBody
Door rust, they are galvanized on the outside skin the inners are plain steel.
Power antennas always have problems.
seat tracks break on the front left power or manual.
Console lids are crap.
Visor swivels will always come loose.
Your trans will flare eventually in 2-3 shifts
Also for turbo cars Oil leaks, cracked DS header, cracked horn ring, PowerMaster failure
When should I expect my Powermasters to fail?? One is 21 years old and the other is 20.
Is that true about the ttype and steelshim gasket? iF SO, I will be purchasing them for my car, I work at GM dealer and the steel shim gasket is only 15 dollar each, as opposed to 40 each for the victor composite.
