Here it is, about the ultimate you can get with a GM 12 bolt bolt in deal for a G-body.
12 bolt GM housing
Mark Williams 35 spline axles
Mark Williams 35 spline spool
Mark Williams captured bearing housing ends (like the 9", but has 12 bolt bolt pattern)
Mark Williams 11/16" drive studs for thin wheels like Weld Alumastars, etc.
Summers Brothers billet steel carrier caps (both sides)
Richmond 4.11 Pro gears
Denny's billet steel pinion yoke 1350 series yoke
Strange Pro Race disc brakes
LPW Ulitmate aluminum girdle/cover
TRZ adjustable spring platforms
Wolfe Racecraft billet spherical housing bushings (in the upper ears)
custom upper control arms and IC relocation device
Wolfe Racecraft double adjustable lower control arms
tabs welded for Wolfe Race craft anti-roll bar attachment (anti-roll not included with rear)
brackets for S&W wheelie bars
slip collar and bracket for driveshaft sensor for data logger
$2600 for the complete setup.
Due to size and weight, needs to be picked up in Westminster, MD.
e-mail geislert@qis.net
I need to move this quickly, so if you have serious interest, let's talk.
59 1/4" wheel to wheel
with a 1" frame notch, a 295/65 D/R on a 10" rim, 6" b.s fit perfectly (79 Malibu)
			12 bolt GM housing
