Underhood parts - intake, plenum, throttle body etc.
T Spool
Shipping is free to the lower 48. PayPal accepted at mikelaforest@comcast.net
Underhood 001
Stock unported intake - includes sensors, water fittings, EGR valve and everything you see in the pic $200 shipped
Stock throttle body complete with TPS, IAC, vacuum block etc. - very nice $120 shipped
Stock throttle body with IAC - has some corrosion in the bore $45 shipped
Stock upper plenum - nicely painted $35 shipped
3/8" aluminum plenum spacer with good used gaskets $25 shipped
Fuel rail - good shape $35 shipped
Underhood 002
Valve covers bead blasted and painted silver - very nice $55 shipped
Billet oil fill/ K&N style breather $30 shipped
(2) stock oil fill tubes with cap $25 shipped ea
Turbo oil feed line $10 shipped
Oil drain block fitting $10 shipped
Oil filter adapter fittings (pair) $10 shipped
Underhood 003
Driver side intercooler bracket - nice original paint $25 shipped
Driver side intercooler bracket - ok shape $20 shipped
Turbo mounting bracket - ok shape $30 shipped
(2) power steering reservoir brackets - good shape $20 shipped ea
Coil mount bracket (V shaped one) - nice original paint $25 shipped
Underhood fender support braces - ok shape $20 shipped
(2 pair) grill springs $12 shipped pr
Underhood 004
Caspers volt booster $45 shipped
Red's Quad Air volt booster $45 shipped
HR driver side poly motor mount - like new $85 shipped
Stock intercooler hose with black oxide clamp $8 shipped
Underhood 005
New heater hose kit (4 hoses) $25 shipped
New power steering pressure hose $25 shipped
New stock style adjustable wastegate actuator (not the high boost version) $65 shipped
Again, shipping is free to the lower 48. PayPal accepted at mikelaforest@comcast.net
ill take
sent payment
Billet oil fill/ K&N style breather $30 shipped - Pending to Joe S.
(2) stock oil fill tubes with cap $25 shipped ea - Painted one SOLD to teegee
Underhood fender support braces - ok shape $20 shipped - Pending to Joe S.
Red's Quad Air volt booster $45 shipped -PENDING to Wheee
New power steering pressure hose $25 shipped - SOLD to 84ttype-hotair
84ttype-hotair, the fender braces were already spoken for so I will refund the $20 back to your PayPal now....thanks
PayPal sent.
Thanks,
Joe
If it's for the stock 3.8, I'll take the "HR driver side poly motor mount - like new $85 shipped"
Let me know if still available.
Update
Stock unported intake - includes sensors, water fittings, EGR valve and everything you see in the pic $200 shipped PENDING to CraigT
Stock upper plenum - nicely painted $35 shipped PENDING to CraigT
Fuel rail - good shape $35 shipped PENDING to CraigT
Billet oil fill/ K&N style breather $30 shipped SOLD
(2) stock oil fill tubes with cap $25 shipped ea Unpainted one left
Oil drain block fitting $10 shipped PENDING to CraigT
Underhood fender support braces - ok shape $20 shipped SOLD
Red's Quad Air volt booster $45 shipped PENDING to wheee
HR driver side poly motor mount - like new $85 shipped PENDING to NOKA72
New heater hose kit (4 hoses) $25 shipped PENDING to NOKA72
New power steering pressure hose $25 shipped SOLD
This is what's left
Stock throttle body complete with TPS, IAC, vacuum block etc. - very nice $120 shipped (this has been ported)
Ignition module bracket (V shaped one) - nice original paint $25 shipped
Caspers volt booster $45 shipped --I'll take this if still available. Let me know...
What's left
New stock style adjustable wastegate actuator (not the high boost version) $65 shipped PENDING
Wastegate actuator
Mike,
Your payment has been sent thru PayPal for the wastegate actuator.
Thanks Dave
Make reasonable offer
I'll take the plenum spacer, let me know where to send payment...
