carryon525
- Feb 22, 2016
On my old GN it was easy as all I had to do was open hood turn a yellow dial to the right or left. The GN I have now I'm not sure I understand how to actually turn up or down the boost on top of that I have the RJC boost controller piece on it which I was under the impression that's how I do it. I also just read this on RJC's site and I noticed it said eleiminate the Y connector? I still have mine one the car???The RJC boost controller works totally different from the factory set up. you run the vacuum line from the turbos compressor through the controller directly to the WG actuator eliminating the factory “Y” and the WG solenoid. (leave it plugged in electrically to a avoid check engine light).
Can someone explain to me exactly how I do this? Also, a Buick friend of mine mentioned to me that I should check the "puck" to make sure its opening and closing properly and if not clean it? How, where, and what are the steps. Its a shame I'm asking because I had my old GN down pat!
