Ungrading to -10 feed, what kind and micron fuel filter you using?
Opps, title SHOULD say UPGRADING!!!
Looking to do this upgraded before BG. Loking to stay away from any problem brands and get the right micron.
Thanks!!
I personally did a 100 micron right out of my cell then a 25 micron inline...all stainless from racepartsolutions. A lot of guys run 10 micron but I am not having any problems w/ the 25 micron.
Thanks!!
-10!? Shooting for 1500 hp? If your using this on that pt-51 combo the factory lines with alittle pressure will work fine. Making over 500whp on my OEM 5/16 hard lines with e85.
I used the inline 60 micron disc type filter pre and it restricted my fuel pump horribly. I'd go with a 150 pre SS. And a paper golden rod post. They filter down to 5-10 micron, flow great, are cheap, and ethanol compatible.
http://www.wayfair.com/Goldenrod-GO...9300-OGR1024&gclid=CKTYoOOk_LICFSWoPAodVnQA9w
i wouldnt run that goldenrod setup
from their specs
Operating Pressure: 50.0 psi [Max]
from their specs
Thats the wayfare screwing up the description. That is Recommended high pressure. I've ran over 75psi on 3 of my cars. Many others using it too. I actually mic'd the metal thickness when I opened and inspeced my filter the first time. Same thickness as a standard oil filter. 50psi is nowhere near burst pressure. I tried to blow one with my air compressor. Sat at 120psi all night. No signs of any kind of problem. Filter element inside was perfect as well. No shifting etc.
