Unidentified Noise...Help
nash421
Can any help identify this noise?? I have good compression in all cylinders. new plugs and wires. rockers seem ok. Turbo spins freely but has bubbles coming from where exhaust goes into the bottom of turbo. Didnt identify fluid yet. Thanks
So what dose the noise sound like can you take a vid or pic? Where does the noise sound like it coming from?
Need way more INFO.....
I have alot more info to post about it i'm just exhausted been wortking on this for the past 3 days straight thru and its driving me nuts!!
Did you say long Tubes? Are you running exhaust? Or just out the DP. Definitely got an exhaust leak.
Fluid coming from where exhaust goes into bottom of turbo... is it water? Water vapor is a component of exhaust gases. That would tell me for sure that there is an exhaust leak between the passenger exhaust manifold and turbo. Your video sure sounds like your car has an exhaust leak.
Sent from my SCH-I535 using Turbo Buick
