I want to know if I unplug the egr and remove the whole system, block off the vacuum lines, and put a block off plate on the intake, will I get a code with the extender extreme chip?
This is going to be my new set-up: T-Top 86 Grand Nationals 109 block with weisco forged pistons and 2 billet center main caps, M&A aluminum heads, roller rockers, port match lower intake ,te63 a.r .82, erson 214/214 cam, smc alky injection (95 % etanol), 25.5lbs boost, 94 octane, hooker cat back with dyno max ultra flow muffers, kenne bell headers, 60 lbs injectors, extender alky chip with 23/21 timing, with a gen 2 with a LS1 maf,thdp, mease 24 row IC, PTC 3200 stall 9 1/2 convertor, Ron Custom max boost brake module, MT drag radials (275/60/15) , rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, Weld Drag Lites with skinnies up front, electric exhaust, hr rear sway bar, no front sway bar, 90/10 lakewood in the front and 50/50 lakewood shocks in the rear with energy suspension poly bushings all over, boxed rear lower control arms, Big mouth cold air with an AFE air filt
Thanks alot for your help, it will be greatly apreciated.
Marco.
T-Top 86 Grand National 62000 km)
stock long block, stock suspension, 12 inch red stripe convertor (2800stall), te44, smc alk injection (95 % etanol), 25.5lbs boost,( boost spike 28 psi in 1st gear), 94 octane, hooker cat back with dyno max ultra flow muffers, 42 ½ lbs 009 injectors, turbotweak alky chip with 23/21 timing, thdp, mease 24 row IC, Ron Custom max boost brake module, MT drag radials (275/50/15) 3720lbs race weight with driver. (Torque convertor locked only after car shifted in third), rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, comp cam 980 valve springs. Weld Drag Lites with skinnies up front, electric exhaust cut-out.
BEST E/T
60FT=1.53
1/8= 7.25
1/4= 11.48
MPH=120.82
BEST 60FT=1.52
I have a gen 2 with an extender chip and LS1 maf, hr rear sway bar, no front sway bar, 90/10 lakewood in the front and 50/50 lakewood shocks in the rear with energy suspension poly bushings all over, boxed rear lower control arms. MT 275/60/15 drag radials. Big mouth cold air with an AFE air filter. The times above were done with out these parts.
Marco.
BEST E/T
60FT=1.53
1/8= 7.25
1/4= 11.48
MPH=120.82
BEST 60FT=1.52
